OBD port not working
  • 52,797 POSTS
There is a problem with the fuse box as it is not providing power to the fuses.
The fuse box must be inspected.
Thursday, November 8th, 2018 AT 2:57 PM
RICKSHAULING
  • 21 POSTS
Okay thanks.
Thursday, November 8th, 2018 AT 2:58 PM
  • 52,797 POSTS
You are welcome.
Keep me updated and we will continue to help if needed.
Thursday, November 8th, 2018 AT 3:05 PM
RICKSHAULING
  • 21 POSTS
  • 2007 FORD F-150
  • 4.2L
  • 6 CYL
  • 127,000 MILES
I have a 2007 Ford F1 50 V6 4.2 L OBD sensor will not work cigarette lighter will not work and the 12 volt accessory on the dashboard not work all fuses are good. Could you tell me what might be the problem?
Friday, November 9th, 2018 AT 12:18 PM (Merged)
  • 52,797 POSTS
Hello again,
Did you do the checks I suggested in your other post?
What have you done to check the voltages?
RICKSHAULING
  • 21 POSTS
With a 12 volt testing light I checked both sides of the fuses number 41 and 39 neither side is working, but fuse 110 works fine no power from either fuse 41 or 39. Also with key in on position check the fuse box still no power.
  • 52,797 POSTS
Okay, I am going to get these two posts combined so there is no confusion.
RICKSHAULING
  • 21 POSTS
Basically what is going on is there is no power at the fuse box to fuse 41 for the cigarette lighter and OBD port. The fuse 39 works the 12 volt on the dash no power at the fuse box either with fuses in or out.
  • 52,797 POSTS
I know, I read that before.
As I stated, you need to remove or look at the fuse block as the power comes from the fuse box itself. Once you get power back to the fuse box, you will have power to the connector.
RICKSHAULING
  • 21 POSTS
Okay thanks. I will take out the fuse box and check wires and box itself. Thanks
  • 52,797 POSTS
You are welcome.
Keep us updated.
Always glad to help.
RICKSHAULING
  • 21 POSTS
I want to thank everyone for their help. I found out what the problem was when I had a new junction box installed two months ago. They put the wrong one in the truck all the numbers matched up except for the letters at the end. Mine was a CB they installed at FA which fuse 39 and 41 was deleted. Which meant no OBD port no cigarette lighter and no 12 volt auxiliary port on dash. Ordered a new one installed it everything is working fine. Thanks everyone for your help and support.
Saturday, November 17th, 2018 AT 3:47 AM
  • 52,797 POSTS
You are welcome.
Good find.
Saturday, November 17th, 2018 AT 5:06 AM
