Hard starting
KEN L
  • MASTER CERTIFIED MECHANIC
  • 48,571 POSTS
I need to hear the engine cranking over. Can you please shoot a quick video with your phone so we can see what's going on, that would be great. You can upload it here with your response. Please use a jumper or install a good battery.
Friday, August 23rd, 2019 AT 1:31 PM
STEVE W.
  • 13,630 POSTS
From your description I don't think it is engine related as that was running okay until the battery voltage drop shut it off. Being a 1997 I would go to the old "pull the fuses to find the draw" test. To do that, disconnect the battery ground and connect a light bulb between it and the battery post. Disconnect the under-hood light if it has one. Now start pulling fuses until the light goes out or goes very dim. Then look up what that fuse feeds.
https://www.2carpros.com/articles/car-battery-dead-overnight
I would also pull the wiring off of the alternator as one of the first tests. I've seen more than a few "new" parts that were junk straight out of the box..
Friday, August 23rd, 2019 AT 4:31 PM
YOITSJUSTME
  • 34 POSTS
Okay, well took the battery and the alternator and had both tested and they both tested good. Reinstalled both and truck started. Haven't had the chance to do the fuse test yet. Could the starter or solenoid be the culprit. Will get the fuse test done this weekend.
Thanks,
Tj
Friday, August 30th, 2019 AT 10:09 PM
STEVE W.
  • 13,630 POSTS
Once you do the testing you might find the draw. The starter or solenoid shouldn't be the issue. They need to be on to create a draw.
Friday, August 30th, 2019 AT 11:17 PM
YOITSJUSTME
  • 34 POSTS
Still trying to complete the fuse test however it keeps burning out my test lights before I can get a fuse pulled.
Friday, September 13th, 2019 AT 1:45 AM
STEVE W.
  • 13,630 POSTS
If the draw is that high switch to a larger bulb like a headlight or flip it around and pull the fuse first then see if the draw is still there. Another method is to use what is known as voltage drop and test across the fuse itself. Take a look at this video showing this method.
https://www.youtube.com/watch?v=lRcj1fQcWwU
Friday, September 13th, 2019 AT 8:24 AM
