trouble starting
1991 CHEVROLET
300,000 MILES • 4.3L • 6 CYL • 4WD • AUTOMATIC
THAT_1_GUY
I have a 1991 Chevy s10 blazer 4x4 and I'm having trouble with starting it...it will start but sometimes die right away and other times it will stay on for a few seconds or I have to keep pumping the gas and sometimes even that won't work but once it stays on it runs fine
Dec 19, 2015 at 8:24 AM
JOHNNYT73
  • 924 POSTS
I would take a look at your idle air control valve
Dec 19, 2015 at 9:41 AM
THAT_1_GUY
How should it be adjusted..I'm trying to learn this stuff so I don't have to pay someone else to fix it
Dec 20, 2015 at 2:40 AM
THAT_1_GUY
Probably should of said it was a carbirated engine...4barrel carburetor
Dec 20, 2015 at 2:49 AM
  • 110,248 POSTS
Have you checked for vacuum leaks? Have you checked the fuel filter?
Dec 20, 2015 at 10:22 AM
  • 110,248 POSTS
Did you say 4bbl? What has been done to the vehicle? It should be a 4.3L FI
Dec 20, 2015 at 10:23 AM
THAT_1_GUY
It is a 4.3....but has a 4 barrel carburetor on it ........I personally didn't do anything to it...it was given to me like that...
Dec 21, 2015 at 2:18 AM
