Will not start up
100,000 MILES • 2.7L • 6 CYL • 2WD • AUTOMATIC
WENDY HELMS
Replaced fuel pump it still won't start. sprayed starter fluid and it started but wouldn't run.
Mar 20, 2022 at 9:30 AM
SQM
  • 6,383 POSTS
If you are able to start the engine for a little bit with starting fluid, it points to fuel delivery issues.
Are you able to verify that the pump is turning on?
A faulty relay will keep the fuel pump from working.
If there is not enough fuel pressure the engine won't start.
Which could be due to a clog in the fuel line or a bad fuel pressure regulator.
This vehicle should have 58 PSI (+/- 5 PSI) of fuel pressure with the key on and engine off.
Here is a guide on how to test the fuel pressure:
Mar 20, 2022 at 4:26 PM
