1999 Chrysler 300M Overheats Won't Start
MR.CARVIN2
I have a 1999 chrysler 300m 128,00 3.5 L it overheated and I kept driving it until it stop running. I replaced the radiator,thermostat,spark plugs,warter pump and it still will not start
Sep 22, 2007 at 3:52 PM
JDL
  • 16,098 POSTS
Sorry about the late reply.
If you drove it till the engine seized, you probably have internal engine damage. I'd have to visually check for spark at the plugs, engine cranking. Then check proper fuel pressure. Check cylinder compression. Check oil pressure.
Mar 17, 2015 at 2:38 AM
Suggested Repair
Because the engine was driven until it stopped after overheating, suspect internal damage. Check for spark at the plugs, whether the engine cranks, fuel pressure, cylinder compression, and oil pressure.
Conversation Summary
A 1999 Chrysler 300M with a 3.5L engine overheated and was driven until it stopped running. The radiator, thermostat, spark plugs, and water pump were replaced, but it still will not start. The expert said continued driving may have caused internal engine damage and recommended checking spark, cranking, fuel pressure, compression, and oil pressure.
