wont start.. not getting any power
160,000 MILES
NEV2LATE
My car keeps having problems starting... the lights and radio are on. I got a jump it started but the next morning would not start agian.(not turning over ..silent) I replaced the battery, ignition and ignition switch, starter relay switch, battery connection cables. The alternator is about a year old so I didnt replace it. What else could cause the car not to fire up?
Aug 3, 2013 at 2:25 AM
CARADIODOC
  • 34,414 POSTS
Forget the alternator. That doesn't do anything until after the engine is running. First shift to neutral and try to start the engine. If that doesn't work, have a test light or digital voltmeter handy so we can take some measurements. You'll need to remove the starter relay from its socket in the under-hood fuse box, then we'll take four readings with the aid of a helper.
Aug 3, 2013 at 8:28 AM
