1992 Chrysler 5th Avenue will not start
141,000 MILES • 6 CYL • 2WD • AUTOMATIC
GRADYRF
car starts and runs fine with the help of starting fluid. but will not start without it?
Oct 11, 2010 at 1:21 AM
JDL
  • 16,098 POSTS
I'd use a gage and check fuel pressure. Also, check for applicable mil codes. You may need to check actual voltage available at the pump, ground also. Some of the national brand autostores used to loan out a fuel pressure gage. For the 3.3, fuel pressure 46--50 psi, check it key on engine off.
Oct 11, 2010 at 2:08 AM
GRADYRF
thanks
Oct 11, 2010 at 2:26 AM
