I had a mechanic change my distributor for me. Found it would start yet not run, changed fuel pump then it ran but rough and had to keep at 1700 rpm to run, or it would cut out and shut off. I asked him to tune it up after changing out the pump (for some unknown reason he thought it was not starting and turned the distributor 180 degrees. Then he burnt up the starting trying to start it). This was so frustrating I waited six months to work on it again! I put a new starter in. Now it will not start at all so the mechanic put piston one at top end then moved the distributor to one. Still will not start just backfires through intake. (does not even act like it is going to start) The mechanic got frustrated and put the old distributor back in yet put the new cap and rotor on it. (said he never liked how the new one lined up, it was off 1/8 of a turn?) Since then I have personally removed the distributor, set piston one at top and put the starting point on the distributor at one. Still backfiring through intake it acts like it does not even want to start just backfiring through the intake "ugh"(do not know why the mechanic did not just leave the new one in there and turn it back around 180?)
Now I am beside myself trying to figure out what to do. I believe I put cylinder/piston one to top. I viewed it with a small bright LED and a mirror. I could see movement in the spark plug hole, yet could not really tell if it was the valves, cam or piston? When metal looked closest I stopped turning the engine, a screw driver would not go in very far so I figured that must be it. (I have checked the plugs, checked the firing order and all cables etc., are set correctly, checked the fuel and pressure "all good", took off air flow sensor, cleaned with AF cleaner, and checked all fuses). Am I missing something here? Please let me know and "thank you so much for your time and attention in this matter."
Kind regards, Kevin
Kind regards, Kevin
Jan 22, 2018 at 12:09 PM
