Will not start without priming with starting fluid. I have replaced the fuel pump, filter, hard lines from tank to engine, distributor cap, button, distributor, ignition coil, air flow sensor, plugs, and wires. you can smell the fuel after you crank it a couple times. I have tested my fuel pressure and made sure I was getting spark through the wires at the plugs, I was. once you spray the fluid in the intake it starts right up and runs pretty well. doesn't have a miss or any hesitation in it while running just cant get it to start with out the primer. I have also redone the intake gasket and all that. I have the spider injection in it and I just cant figure out what it is. I have been told my injectors and distributor but the distributor is new and again when it is running it has a lot of power and runs and even idles smooth. do you have any suggestions on what I can do or try to figure out what this problem is?
Dec 28, 2018 at 11:41 AM
