1995 Chevy S-10 wont start but turns over good
DANIELEATON2003
  • 1995 CHEVROLET S-10
  • 6 CYL
  • 4WD
  • 117,000 MILES
It wont start idk whats the plomblem
Thursday, September 25th, 2008 AT 9:39 PM
Do below and tell me what's missing fuel or spark
Get a carb cleaner and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, distributor pick-up coil, ignition control module, cam and crank sensors-
Thursday, September 25th, 2008 AT 9:52 PM
