Just to be sure this is the same issue from last May? After it overheated it will not turn over or anything?
If it has been sitting since then we need to check the battery using this guide.
However, if the battery is fine and it will not turn over after this happened then we need to try and turn the motor by hand with a socket on the crank pulley and make sure it is not locked up.
However, if this is a different issue then we need to get a new post started as we need to keep each one to one topic.
Let us know and we can go from there. Thanks
SPONSORED LINKS
Monday, April 19th, 2021 AT 6:49 PM
