It is acting like it not getting fuel?
T-SMITH
  • 18 POSTS
No burn marks and I do have the stock one I've changed it back to the stock the other day to see if that was it but it still done the same thing
Sunday, July 30th, 2017 AT 8:30 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 48,363 POSTS
Okay check the valve springs on the other side.
Monday, July 31st, 2017 AT 11:31 AM
T-SMITH
  • 18 POSTS
I checked them and they all look good
Monday, July 31st, 2017 AT 6:24 PM
KEN L
  • 48,363 POSTS
Nice work, Have you checked the fuel pressure yet? If the pressure is low it can cause the engine to go lean. Here is a guide to help you.
If you don't have a gauge you can rent one for free from the auto parts store.
Please let us know what you find.
Cheers, Ken
Wednesday, August 2nd, 2017 AT 10:30 AM
T-SMITH
  • 18 POSTS
I've checked it after I put the injectors in and it's about 40 psi
Wednesday, August 2nd, 2017 AT 10:48 AM
KEN L
  • 48,363 POSTS
Okay, here is what I would do, replace the ignition rotor. Then if it still does it try to spray starting fluid in when the engine is acting up to see if it is fuel or ignition related.
Wednesday, August 2nd, 2017 AT 11:15 AM
