Engine will not crank over - starter not working?
RIVERMIKERAT
  • 6,110 POSTS
Our reference doesn't list an S-Type in 1999. What's the full symptom and question?
Friday, May 26th, 2017 AT 1:47 PM (Merged)
  • 0 POST
  • 2004 JAGUAR S-TYPE
  • 120,000 MILES
The car was parked and suddenly the car wont even crank but the bat has full power.
RANDICO
  • 174 POSTS
This has to be the most popular problem with the Jaguar since it was in production, You will need to jump the starter by direct method, if it doesn't crank there you will need a starter. If it start there you will need to test the ignition switch, and the brake switch and the neutral postion, if they all check out A BCM is needed
