Acted like it was out of fuel now it will not start
195,000 MILES • 4.3L • 6 CYL • 4WD • AUTOMATIC
SWAYNE
Started to take off from stop sign when it started to act like it was running out of fuel. I have three quarters of a tank so that is not an issue. it is getting fuel but when I turn it over it does not seem to be getting spark and it will not start now.
Aug 15, 2017 at 11:50 AM
HARRY P
  • 2,292 POSTS
Fuel pumps are very common on these trucks. I had one shut off just like that. I was pulling out of the park, drove about fifty feet, and it stalled. Towed it home, checked fuel pressure and it was around 10 psi (truck takes 60 psi to start and around 50 to run). Another one quit running when I went to leave work. It started and idled, I put it in gear and it stalled a few seconds later. Bad pump.
In short, start with checking fuel pressure. Here is a guide for that: https://www.2carpros.com/articles/how-to-check-fuel-system-pressure-and-regulator
You can borrow the pressure gauge from AutoZone for a deposit (refunded when you return it).
If you really think it's not a fuel pressure issue, then you can get a spark tester (maybe $15.00 not part of the loan-a-tool program, so you have to buy it) and check the sparks. Here is a guide for that: https://www.2carpros.com/articles/how-to-test-an-ignition-system. And here is the tester that I use listed on Amazon: https://www.amazon.com/Lisle-20610-Inline-Spark-Tester/dp/B0002STSC6/ref=sr_1_3?ie=UTF8&qid=1501325755&sr=8-3&keywords=spark+tester
Jan 29, 2021 at 5:33 AM
