1996 Chevy Blazer will not start
JWCEAE
  • 1996 CHEVROLET BLAZER
  • 6 CYL
  • 4WD
  • 126,000 MILES
Hi I have a 1996 chevy s-10 blazer. Recently it won't start. If I pour gas in the throttle body it will start and run fine. And sometimes it will stall and even if it is worm it won't start back up unless I pour gas in it again. When i'm driving down the road it runs perfectly fine. Could the fuel pump be going bad or the preassure regulater. What is the fuel preassure supposed to be for it. Its a 4.3 vortec with a throttle body. Any suggestions u have would be very helpful.
Saturday, November 29th, 2008 AT 6:02 PM
Do you hear the fuel pump come on when key at run position? If so check the fuel pressure should be for throttle body-9-13psi
Saturday, November 29th, 2008 AT 6:05 PM
JWCEAE
Yeah the pump is working
Saturday, November 29th, 2008 AT 7:33 PM
Well give me the fuel pressure readings and I'll take it to another system-your lucky its not the spider-its a lot tougher
Saturday, November 29th, 2008 AT 7:36 PM
JWCEAE
Ok I will have to get back to you tomorrow or monday I have to get the fuel check from my uncle
Saturday, November 29th, 2008 AT 7:41 PM
