1996 Chevy Blazer Wont start
STRO206006
  • 1996 CHEVROLET BLAZER
  • 6 CYL
  • 200,000 MILES
I have a 1996 Chevy Blazer that runs great when it starts. A while back I was parked in a lot and the nose was pointed down and it would not start. I hd it towed home and once it was on level ground it fired right up. Yesterday I was parked at the park and I went to leave and the same thing it would not start. I can here the fuel pump and it will try to start and almost get going but just wont start. I have checked the relay and it tested good. Any suggestions?
Monday, May 18th, 2009 AT 3:54 PM
Check the fuel pressure with a fuel pressure guage designed for your fuel system to rule out a failing pump
Monday, May 18th, 2009 AT 3:59 PM
BUDDYCRAIGG
  • 2,262 POSTS
Do a fuel pressure test, the hose in the tank, between the pump and the sending unit may be failing.
Are you able to drive it until the fuel gauge gets to empty?
Monday, May 18th, 2009 AT 4:04 PM
STRO206006
I checked the pressure and it is about 45 or so. I cant get it to start so no I can't run the gas out. I wish. It is nearly full. Heavy tank.
Monday, May 18th, 2009 AT 4:17 PM
Your fuel pressure is way too low it should be 60-66 psi
Monday, May 18th, 2009 AT 4:22 PM
STRO206006
Would it be the pump or the regulator? I tested the pressure on the schrader valve on the fuel line up near the manifold.
Monday, May 18th, 2009 AT 6:38 PM
Could be the fuel pressure regulator or injector/s leaking dropping the pressure sounds more like a failing fuel pump
Monday, May 18th, 2009 AT 7:01 PM
