will not start when below freezing?
237,000 MILES • 4.8L • V8 • 4WD • AUTOMATIC
POOR-RAY
Tried crank censer no luck checked amps when turning over to the starter great voltage as I release ignition it tries to fire we have no spark at plug until i release ignition and some times it does start idles real low also checked grounds
Dec 5, 2013 at 3:07 AM
HMAC300
  • 48,601 POSTS
check fuses underhood then scan for codes and check fuel pressure with a gauge auto parts rent them. It may be abad ignition switch as well.
Sep 2, 2020 at 7:23 AM
POOR-RAY
fuses are good fuel pressure 55-62 no codes I bypassed ignition switch with hand held still the same some one said master relay what is this?
HMAC300
  • 48,601 POSTS
there is no master relay there is a starter relay but no master. and if it turns over the relay is good. check resistance of cam sensor as it will not start and not send a code. check enginecoolant temp sensor for resistance if it is 32 degree s it shold be around 9840 ohms higher if lower than 32. if it's not replace it. it could also be a map sensor they will cause a no start as well.
POOR-RAY
Replaced map/crank/temp/cam sensor still doing the same thing
HMAC300
  • 48,601 POSTS
check to see if ignition switch is sending power out likeisit sending 12 volts out that it gets in as these have gone bad on a lot of vehicles. other wise have apro scan it with a pro scanner. it may be an anti theft problem.
