Why is my alternator light flickering and sometimes staying on?
UHSNOEBIRD
  • 342 POSTS
Okay, thanks.
Tuesday, November 2nd, 2021 AT 1:16 PM
  • 52,797 POSTS
You are welcome.
Always glad to help.
Let me know if you have any other questions.
Tuesday, November 2nd, 2021 AT 1:18 PM
UHSNOEBIRD
  • 342 POSTS
Roy, let me tell you what I tried.
I started my 1997 Nissan Pickup up and put my voltmeter across the battery terminals like you ask me to do to my 2005 Toyota Camry.
I set the voltmeter to the AC voltage setting just like I did on the Camry and the voltmeter showed roughly the same voltage as the Camry, the ac voltage went up to about 180 volts an dropped down some and right back up to a high voltage.
It never showed zero volts.
Tuesday, November 2nd, 2021 AT 5:02 PM
  • 52,797 POSTS
Based on your readings, you need an alternator for the Camry.
I don't know what else to tell you. There should be 0 volts of AC when the engine is running.
Wednesday, November 3rd, 2021 AT 1:58 AM
UHSNOEBIRD
  • 342 POSTS
Wednesday, November 3rd, 2021 AT 5:09 AM
  • 52,797 POSTS
You are welcome.
Wednesday, November 3rd, 2021 AT 10:08 AM
UHSNOEBIRD
  • 342 POSTS
I looked at it today where the hot wire connects to alt. It got hot and melted some insulation off and when I attempted to take the nut off the mounting shaft broke.
Wednesday, November 3rd, 2021 AT 11:39 AM
  • 52,797 POSTS
Did you disconnect the battery first?
Wednesday, November 3rd, 2021 AT 12:12 PM
UHSNOEBIRD
  • 342 POSTS
Yes.
Wednesday, November 3rd, 2021 AT 12:13 PM
  • 52,797 POSTS
Okay, you will have to replace the wire end and then replace the alternator. Too much current flow from the old alternator caused that.
Wednesday, November 3rd, 2021 AT 1:25 PM
UHSNOEBIRD
  • 342 POSTS
Roy, now today I had the voltmeter set on AC Voltage and it read 30 volts. Why is it reading this amount?
Thursday, November 4th, 2021 AT 12:14 PM
  • 52,797 POSTS
Okay, it does not matter at all. The fact that it has more than 1 volt says the alternator is no good. You need to replace the alternator.
Thursday, November 4th, 2021 AT 12:43 PM
  • 52,797 POSTS
Anytime my friend.
We are here to help.
Thursday, November 4th, 2021 AT 5:18 PM
