1988 Toyota Camry battery discharge light
OCT21NYY
  • 1988 TOYOTA CAMRY
Electrical problem
1988 Toyota Camry 4 cyl Front Wheel Drive Automatic
My battery discharge light is on and the battery drains after a few days, is this a faulty alternator and if so how can I test this out so as not to replace something that is working correctly?
Tuesday, September 2nd, 2008 AT 11:57 AM
The alternator might not be putting out or the battery is not taking the charge could also be a short ciruit within the electrical system that's draining the battery overnite.
Tuesday, September 2nd, 2008 AT 5:34 PM
OCT21NYY
Is there a way for me to tell if the alternator is faulty or to find out if there is a short. The car isn't worth more than $500-$700!
Tuesday, September 2nd, 2008 AT 7:09 PM
Get a voltmeter read the battery-record the reading then start the car while running record the reading-if the voltage while running is 2volt higher than before you start the car-the alternator is doing its job.
Check for short circuit
http://www.2carpros.com/forum/automotive_pictures/12900_parastic_draw_1_25.jpg
Wednesday, September 3rd, 2008 AT 3:30 PM
