White smoke in the tailpipe
14,300 MILES • 4.6L • V8 • 2WD • AUTOMATIC
DONNELL JEFFERSON
I have the car listed above Sedan. It's not overheating but white smoke is coming out of the tailpipe.
Mar 25, 2022 at 1:14 PM
  • 110,248 POSTS
White smoke usually indicates engine coolant is entering the combustion chamber and being burned by the fuel. This most commonly is the result of a faulty head gasket.
First, check the engine coolant level to determine if it is low.
If it is, take a look through this link that explains how to check for a bad head gasket:
Also, I'm not sure where you are located, but outside temperature can cause steam from the exhaust that usually goes away after a few minutes. Could that possibly be what you are experiencing?
Note: If you could record what you are seeing and upload it for me to see, I should be able to tell if it is coolant being burned.
Mar 25, 2022 at 1:30 PM
