The starter is not engaging the ring gear on the drive plate, you may have 2 problems here, first the starter will have to be removed and replaced or o. Hauled and secondly you will have to check the teeth on the drive plate as if they are badly warn the new starter will have the same problem, if the ring gear is worn, the transmission must be removed to replace it.
SPONSORED LINKS
Friday, November 20th, 2015 AT 9:09 PM
