2003 Ford Expedition No Start Buzzing
KEELKLAN
2003 ford expedition wont start and makes a buzzing noise from under the dash, It has 80000 miles and is the big V8
Nov 4, 2007 at 11:17 AM
BMRFIXIT
  • 19,053 POSTS
[quote:f4683ee354="keelklan"]2003 ford expedition wont start and makes a buzzing noise from under the dash, It has 80000 miles and is the big V8[/quote:f4683ee354]
check list
have the org key
lock and unlock the doors using the remote
battery fully charged if not try a jump
try moving the shifter from P to N and try starting
check the relays under the hood
check or and tap on the starter
good luck
Nov 4, 2007 at 11:42 AM
ALLENSLPD
Any luck? I have the same thing going on??
Sep 15, 2009 at 4:32 AM
BMRFIXIT
  • 19,053 POSTS
Try and check battery
get a jump see if it start
check battery and terminals and check starter too
start with a jump 1st
Sep 15, 2009 at 10:09 AM
Suggested Repair
Confirm the battery is charged and the terminals are clean, and try a jump start first. Use the original key and lock and unlock the doors with the remote. Try starting in Neutral, then check the under-hood relays and the starter.
Conversation Summary
The owner of a 2003 Ford Expedition V8 with 80,000 miles reports that it will not start and makes a buzzing noise under the dash. The expert recommends verifying the original key and remote lock/unlock, checking battery charge or jump starting, trying Neutral, and inspecting the under-hood relays and starter. Another owner reports the same symptom, and the expert again prioritizes the battery, terminals, a jump start, and the starter.
