The engine shut off after overheating, now it runs rough, and the Check Engine light is on
243,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
MARY WEST BECKER
The car has an overheating problem. There was a blown fuse but that has been replaced. It was for the fan that cools the engine, but the car still overheats and then dumps all the coolant. The other night the car overheated and then shut itself off after cooling down I added more coolant and the car eventually started again but the check engine light came on and now the car rides rougher than before and when idle at a light it shakes like it wants to shut off and the temperature gauge fluctuates, but I don't think it's accurate any longer. The check engine light sometimes will now flash and once I can get the car up to a speed it feels comfortable at the engine light will then go back to on, but non flashing warning. the cooling fan sometimes kicks in but will make an awful sound. It's possible my water pump is bad, is there a relay or a fuse for the water pump? and if so, where is it located? I know the water pump and outlet and gaskets need to be replaced as does the engine fan and the entire thermostat and seal and gasket need to be replaced as well and eventually probably the radiator too, but my husband wants to start with the water pump and hoses first. can you offer any advice please?
May 16, 2022 at 6:20 PM
I think we may have a blown head gasket at this point so let's start with checking the basics for this and go from there.
Since this just happened you may not have the signs yet of mixing oil and coolant but that doesn't mean this is not the issue.
So, if you can test the head gasket using the chemical method then that will be definitive.
Also, we can check the compression and see if this is low as well.
Basically, we need to start with this because I suspect we are going to find the head gasket is the issue.
Let me know if you have questions on this.
May 17, 2022 at 12:50 AM
