Water in the oil
120,000 MILES • 3.1L • V6 • FWD • AUTOMATIC
PEAPICKER
I have somehow gotten water in the oil and car overheated. Could it have been caused by a bad PCV valve or thermostat or do you think there is another cause? Car sat up for almost a year without being ran. But was in perfect shape before that.
May 17, 2017 at 4:31 AM
HMAC300
  • 48,601 POSTS
these were famous for blowing the intake gaskets normally at front or back so check for coolant at front/rear of engine. it might be a good idea to pressure test it to see if you have a head gasket problem as well.
May 17, 2017 at 5:07 AM
