My 1996 lumina started knockin 2 days ago.
There is coolant leakage into engine oil which causes oil to be milky. I searched on the net and found out that intake manifold gasket failure is common problem for Lumina. I probably drove 20 miles with the coolant leaked into oil. Can I still get away with fixing only the gasket or do I need something more to it like rebuilding the engine?
Aug 26, 2008 at 8:24 AM
