Water in oil
240,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
MONICA JENKINS
Radiator cracked so I replaced it but with the same radiator just one inch shorter. Tried to start engine and it cranks but will not turn on. I checked oil and there was water inside.
Aug 9, 2017 at 8:18 AM
STEVE W.
  • 15,418 POSTS
If there is water in the oil you likely have a bad head gasket. The cracked radiator could have been the cause or a symptom, depending upon when it occurred.
Either way you will want to run a pressure test on the cooling system, then decide from there if you want to replace the head gasket. If it has been run like that for a while you may need more than just a head gasket because the chemicals in the coolant can damage the engines bearings, plus water is not a good lubricant. I would do the tests, then price the repair.
Aug 9, 2017 at 8:46 AM
