1999 Honda Accord Oil in coolant - no coolant in oil
1999 HONDA ACCORD
170,000 MILES • 4 CYL • FWD • AUTOMATIC
MATH TOM
VTEC: F23A1 Engine.
Narrowed it to 2 possibilities: a) blown head gasket, and b) internal cracks in engine block. I'm told some engines of this era developed cracks between coolant & oil passages. My plan is to disassemble & inspect head gasket first and if it's bad then replace & reassemble, with new timing chain (it's due). If HG is OK, engine has to be replaced. Any feedback?
Apr 22, 2009 at 7:41 AM
F4I_GUY
  • 3,302 POSTS
What you will probably find is that the headgasket is cracked or torn. You should also get the cylinder head re-surfaced and checked for cracks when it is off the engine.
Cylinder sleeve cracking is pretty rare on these vehicles, so it's most likely just a headgasket issue.
Goodluck.
Apr 22, 2009 at 9:45 AM
