1998 Volvo V70 White smoke, heater smells
179,000 MILES • 6 CYL • 2WD • AUTOMATIC
E_JOLLY
The weather has become cold and every time I turn the heater on, I can smells coolant from the engine inside the car, but this is only when I turn on the heater. Also, I noticed today for the first time that there is white smoke coming from my exhaust pipe when I press on the gas from a stop and when the car starts. Will I need major work done on my engine?
Oct 19, 2009 at 11:50 AM
  • 31,937 POSTS
Hi there,
Get the cooling system pressure tested to check for a leaking heater core, also have a head check done to test for exhaust gasses in the cooling system, do you have to add coolant and is it over heating or have a miss fire or rung rough at idle?
Mark (mhpautos)
Oct 19, 2009 at 1:36 PM
