1993 Volvo 240 Cold Start Problem
AERONCA7AC
'93 Volvo 240, 2.4L, 175,000. I've had this car for 3 winters and when the temp gets below 30 degrees, it starts very rough or not at all. It does not have a dedicated cold start injector like other models. I have replaced the coolant temp sensor, checked the ECU as per the Bently repair manual. No codes are stored in the computer. All injectors have been removed/tested and are in good shape. Seems as if it is getting plenty of gas by the smell of exhaust as it coughs and sputters during attempted start. Once it does start and accellerates above about 1000rpm, it runs fine. (as if a cold start injector had just cut out). Any ideas? Thanks
Jan 15, 2007 at 8:12 AM
SERVICE WRITER
  • 9,123 POSTS
Check your model chassis no. range
244478400-487088
245939100-956470
Market code 30 and 39 early 93 volvo 240s
If yours falls in this group, replace the MFI LH control module with part no. 9146223-4
Jan 15, 2007 at 9:50 AM
BOWSHOCK
My mechanic was stumped for a week, turns out it was the fuel pressure regulator.
Nov 24, 2019 at 9:46 PM
Suggested Repair
If the chassis is in the early 1993 range cited by the expert, replace the MFI LH control module with part 9146223-4. The owner later reported the no-start was resolved by replacing the fuel pressure regulator.
Conversation Summary
A 1993 Volvo 240 started roughly or not at all below about 30 degrees, then ran fine once above about 1000 rpm. The coolant temperature sensor, ECU, codes, and injectors had already been checked. An expert advised verifying the chassis number and, if it fell in a specified early-1993 range, replacing the MFI LH control module. The owner later said the mechanic found the fuel pressure regulator was the cause.
