1988 Volvo 240 Won't Start
Suggested Repair
Use a noid light on an injector connector to confirm the injectors are receiving a pulse. Verify actual fuel pressure, since about 10 psi is only an estimate and pressure is critical on fuel-injected engines. Also note that some Volvo circuits do not power up until the mass airflow sensor detects that the engine is turning.
Conversation Summary
The owner of a 1988 Volvo 240 wagon said it stopped running, briefly ran after a salvage airflow meter was installed, then quit again. Spark, timing, and the timing belt appear good, and fuel reaches the injectors, but the engine will not start and the injectors do not seem to click. The expert advised checking injector pulse with a noid light, confirming fuel pressure, and remembering that some Volvo systems stay off until the airflow meter senses engine rotation.
