1985 Volvo 240 Coolant Leak After Freeze
JOHNNYD
Hey man i know iscrewed up...but
my 1985 volvo 240DL engine colling system had water in it
the system froze
i thought i thawed it all out with hot water
i went for a 1/2 mile drive after letting it warm up for 5 min
my car over heated
i realized i didnt completely thaw everything and ther wasnt any water getting to my engine from the resevoir
then i completely thawed evrythig
now when i put water in the resevoir i can hear it pour out just as fast as i pour it in
it is coming out the bottom rear passenger side of my engine
i dont have my jack to see whats going on
could it be a blown head gasket or could it be the block or...
any way to know?
Dec 18, 2006 at 1:57 PM
2CARPRO JACK
  • 11,533 POSTS
Im pretty sure Volvos have "freeze" plugs.They are metal plugs driven into the sides of the block so when the water freezes and expands, the plugs will pop out of the block instead of cracking it
Dec 18, 2006 at 11:30 PM
Suggested Repair
Inspect the engine-block freeze plugs, especially at the bottom rear passenger side where coolant is leaking. A plug likely pushed out when the cooling system froze. Replace any displaced plug and refill with the proper coolant mixture.
Conversation Summary
The owner of a 1985 Volvo 240DL froze the cooling system, then overheated after an incomplete thaw. After fully thawing it, coolant poured out as fast as it was added and leaked from the bottom rear passenger side of the engine. The expert explained that freeze plugs are designed to pop out rather than let the block crack when coolant freezes.
