1985 Volvo 240 Muffler Noise
XJENNERSONX
I have a 1985 Volvo 240 sedan with 331,500 miles on it (yes, she is quite the trooper). Recently while the car is on, there is a tinny sounding noise coming from the muffler. It gets worse when I am driving or braking, and lessens when I am in park. A friend of mine who has a 240 says it might just be a loose muffler.
I have a small hole in one of the pipes from my muffler which is causing (or I hope this is what's causing it) my car to sound like a motorcycle when I accelerate.
Also when I go up steep hills, my car makes sort of a chugging noise, like it might not make it up the hill.
Any ideas? I know I need an oil change (I'm about 3000 miles overdue, but I don't think that's the reason for all the problems). Thanks!
Aug 6, 2007 at 12:28 PM
  • 31,937 POSTS
Hi there,
It's a bit tricky working out some of these questions from afar, but my best first thought is that a baffle has given way inside the muffler and may be chocking of the exhaust. With the exhaust COLD reach under the car and give it a good thump with your hand, if you hear a rattle noise then replace the muffler, also it's not a good idea to drive around with a faulty exhaust as the fumes can be drawn into the car and that can be fatal.
Mark (mhpautos)
Aug 6, 2007 at 6:20 PM
Suggested Repair
With the exhaust cold, thump the muffler by hand. If it rattles, a loose internal baffle may be choking the exhaust and the muffler should be replaced. Do not keep driving with a leaking or faulty exhaust because fumes can enter the cabin.
Conversation Summary
The owner of a high-mileage 1985 Volvo 240 reports a tinny muffler noise that worsens while driving or braking, a small exhaust-pipe hole that makes the car sound like a motorcycle under acceleration, and chugging on steep hills. A friend suggested a loose muffler. The expert says an internal baffle may have failed and be restricting the exhaust, and recommends a cold thump test: replace the muffler if it rattles, and avoid driving with a faulty exhaust because fumes can be drawn into the car.
