1990 Volkswagen Passat Car stays in 2nd gear at all times.
1990 VOLKSWAGEN PASSAT
172,000 MILES • 4 CYL • FWD • AUTOMATIC
RECEIVER25
  • 11 POSTS
I recently purchased a 1990 VW passat GL, really cheap and the car runs great, the problem that I am having is that when the car is put into drive it starts out in 2nd gear and will not start out in 1st and will not shift into 3rd it seem to be lobed in 2nd for everything. guy that I purchased the car from informed me when I bought car that this is the same problem that he had. He believed that it was an electrical problem. What do you think? Could it be a transmission shift sensor or modules and if so where is it located and how can it be checked out.
He said that A transmission shop checked it and they could not figure it out either, they guessed an electrical problem. I don't want to put alot of money into this car if no need be.
Thanks
May 22, 2009 at 4:00 PM
DOCFIXIT
  • 18,828 POSTS
Hi
Don't like to be bearer of bad news but your trans. has no shift solenoids. It is shifted by speed and hydraulic pressure. Problem could be in valve body or clutch pack siezed.
Hope this sheads light on problem
Thanks for donate
May 23, 2009 at 4:47 AM
RECEIVER25
  • 11 POSTS
Thanks for the information the prior owner thought that it might be an electrical problem, even the transmission shop thought the same. Is this a expensive repair? Or are the part reasonable?
May 23, 2009 at 2:27 PM
DOCFIXIT
  • 18,828 POSTS
Would need trans shop to run pressure tests on trans to see what fault might be.
May 24, 2009 at 8:25 AM
