timing belt
140,000 MILES • 2.8L • V6 • FWD • AUTOMATIC
SUGARCAIN
My timing belt broke when wife was driving, she said it just stopped no loud noise just shut off. now I know it's a interference engine is it at all possible to not bend a valve or crack a piston is there any chance to not have to pull the heads off?
Feb 3, 2016 at 8:16 AM
  • 110,251 POSTS
Chances are it is damaged. However, the only way to be sure is to replace the belt and correctly set timing. At that point, check engine compression. If it is good, you got really lucky If some of the cylinders have no compression, you have bent valves.
Feb 3, 2016 at 8:40 AM
