Strange electrical problems
VOLKSWAGEN
JROD867
I have a 2004 Jetta 1.8t manual transmission. This problem does not happen every time I drive, but enough to be really annoying. The main issue is that when I park and shut the car off the clock and trip odometer reset and the radio shuts off with the key still in the ignition. It seems to be more frequent when I have had the AC on, I have tried shutting it off before turning off the ignition, but it still happens. At times when my dash lights are on they will dim as well as my head lights while driving. Occasionally the car will die when stopped and everything electrical shuts off, but there is no problem starting the car right away. While driving the car will bing 3 times, but there is no warning light to go along with the bings. The auto windows will not always raise/lower the window with a single push but there is no problem if you hold down on the button. With the dash lights on lowering the window has caused the dash/headlights to dim. I have checked the battery and alternator they both test just fine and took it to the dealership and they could not find anything. The car has 49100 miles on it so my warranty is just about up and would like to figure this out before I have to pay anything. Any help would be greatly appreciated
Thanks
Sep 10, 2007 at 4:38 PM
GARFIELD
  • 197 POSTS
The first thing I would try is to look for a loose or corroded ground connection in your dash area. The most common cause for weard electrical gremlins is normally associated with bad grounds. If you have the electrical diagram for your car try and see if you can see if all of the things you are having trouble with share a common ground. If not you may actually have multiple ground probems. Try that first and let me know how things went.
Good luck
Gary
Sep 11, 2007 at 5:00 AM
JROD867
Thanks for the quick feedback, but unfortunately I will never be able to use your advice. A crotch rocket hit my car tonight going about 120 mph and probably totaled my car. Thanks anyway.
Sep 12, 2007 at 2:11 PM
