1985 Volkswagen Jetta Battery Dies
now if you give the battery a jump
the car start you go to the store no problem
that’s tells me the alternator may be OK
if you can drive the car after a jump with no problem
but you can not start after a good run that’s means the battery not holding the charge
and you need a battery
plus the battery is a lot cheaper to replace than an alternator
good luck
Thank you, and God Bless,
Suggested Repair
Have the battery and charging system tested, or check voltage: about 12 volts with the engine off and 14 to 15 volts while running. Inspect battery cables and connections for cleanliness and tightness. If the car runs after a jump but will not restart after a drive, the battery is likely not holding a charge and should be replaced before considering the alternator.
Conversation Summary
The owner of a 1985 Volkswagen Jetta said the battery dies after a short trip and asked how to tell an alternator problem from a bad battery. Experts recommended a free charging-system test or a voltmeter check of about 12 volts off and 14 to 15 volts running, plus inspection of the battery cables. They also noted that driving fine after a jump but failing to restart afterward points to a battery that will not hold a charge, which is cheaper to replace than an alternator. The owner thanked both experts.
