2001 VW Jetta Dies After Sitting
Suggested Repair
Check for a parasitic battery drain with the car off. A small spark when lifting the positive battery cable is normal; isolate the fuse that reduces an excessive spark, then inspect the components on that circuit, including the ignition switch and accessories that stay on. Also have the alternator and its internal regulator tested, since a failing alternator can drain the battery.
Conversation Summary
The owner of a 2001 VW Jetta GLS 2.0 says a new battery did not stop the car from dying after sitting for one day, although it starts fine when driven daily. Experts say a component or accessory may be drawing power with the car off, and a bad alternator or regulator can also drain the battery. They recommend checking for anything left on, testing the alternator, and isolating the fuse associated with the excessive draw.
