1978 Other Volkswagen Models
1978 VOLKSWAGEN
85,000 MILES • 4 CYL • 2WD • MANUAL
LAWDOGG33
i have a volkswagon bus type 2 and need to remove the distributor, how do i do that?
Aug 8, 2008 at 6:59 AM
MECHTRIX
  • 416 POSTS
hello i know these busses well" if you look strait down at the base of the distributor you will see a clamp " part of the clamp is held to the engine by a 13mm nut ...the rest of the clamp is clamped to the post portion of the distributor by a 1in long bolt the head of the bolt is 10mm loosen both of them .....and then give it a slight twist & that thing will pull stait up out of there...ok" good luck if you have anymore questions get back to me ....i hope this helped".
Feb 5, 2009 at 3:19 PM
