1996 VW Jetta Fluctuating Temp Gauge
VOLKSWAGEN
TONY924
1996 VW Jetta Wolfsburg, 2.0L. 90000 miles.
Recently my engine temperature gauge has been
behaving oddly. Normally the gauge goes to
the midline (190 degrees) and stays there.
But if I drive the car more than 40 miles, the
needle starts to creep up past the midway mark
and then moves around erratically. The water
pump was replaced recently and there is no
coolant leak, nor any other symptoms suggesting
that the engine really is overheating. The needle
has never gone all the way to the right; it has
gotten as high as 230. What might cause this?
Aug 3, 2007 at 4:00 PM
  • 75,988 POSTS
[quote:4e0634adf8="tony924"]1996 VW Jetta Wolfsburg, 2.0L. 90000 miles.
gotten as high as 230. What might cause this?[/quote:4e0634adf8]
Have the cooling system flush out and replace the thermostat and report back ASAP.
Aug 4, 2007 at 5:29 PM
Suggested Repair
Flush the cooling system and replace the thermostat, then recheck the temperature gauge.
Conversation Summary
A 1996 VW Jetta owner reports the temperature gauge stays near 190 degrees normally but creeps up and fluctuates after drives longer than 40 miles, reaching about 230. The water pump was recently replaced, there is no coolant leak, and there are no other signs of actual overheating. The expert recommends flushing the cooling system and replacing the thermostat, then reporting back.
