2000 Volkswagen Jetta Won't Start
VOLKSWAGEN
DRERICG
  • 5 POSTS
2000 Jetta, 105,000 miles, 2.0 liter engine. When turned to start, there is no indication of trying to start - starter doesn't engage, engine doesn't turn over. Battery is good, doesn't help to jump. Cables look good and well connected.
I read about the neutral switch in the console. What tips do you have for getting into the console?
What else should I check before removing the starter to have it checked? Would looking at the trouble codes help?
I've looked at the starter to remove it, but it doesn't have standard bolts to remove. Any tips?
Apr 29, 2007 at 2:59 AM
2CARPRO JACK
  • 11,533 POSTS
First you need to test for 12 volts at the trigger wire at the starter (small wire). If it has it then the starter is probably bad. If not then go to the Neutral safety switch
Apr 30, 2007 at 2:52 AM
Suggested Repair
Test for 12 volts at the small starter trigger wire. If voltage is present, the starter is likely bad. If not, check the neutral safety switch.
Conversation Summary
The owner of a 2000 Volkswagen Jetta 2.0 says the engine will not crank, the starter does not engage, and jumping does not help. They asked about the neutral safety switch, trouble codes, and starter removal. The expert advised testing for 12 volts at the starter trigger wire; if present, the starter is likely bad, otherwise check the neutral safety switch.
