what would be wrong with my car if it will turn over but not start??
1996 VW Jetta
110,000 miles on it
1996 VW Jetta
110,000 miles on it
Sep 2, 2006 at 7:02 AM
Confirm fuel and spark. Crank the engine, remove the spark plugs, and check for a fresh fuel smell. If fuel is present, replace the spark plugs. If not, check fuel delivery and listen for the fuel pump to hum briefly at the rear underside when the key is turned to accessory.
The owner of a 1996 VW Jetta with 110,000 miles says the engine turns over but will not start. The expert explains that starting requires fuel and spark, and recommends checking the plugs for a fresh fuel smell after cranking. If fuel is present, replace the spark plugs; if not, investigate fuel delivery, beginning by listening for the fuel pump to prime briefly when the key is turned to accessory.
