Moonroof Stuck on 90 Jetta
1990 VOLKSWAGEN
TREKINOUS
  • 28 POSTS
Hi, I have a 1990 Volkswagen Jetta GL, 1.8L 405,000kms. It has a hand crank moon roof and when i go to crank it open nohing happens, the handle just spins. Is there some sort of cog that may be stripped? I just want to know what could be the problem before I go tearing the roof apart. Help is greatly appriciated.
Cody.
Sep 19, 2007 at 2:44 PM
  • 55,688 POSTS
first look to see if the handle spline is stripped, if so replace the handle, if not you will need to inspect the regulator that controls the roof hatch and replace or repair as needed.
Sep 19, 2007 at 3:16 PM
TREKINOUS
  • 28 POSTS
do i have to take the whole roof liner off in order to check the spline? or does just the handle come off?
Sep 19, 2007 at 3:24 PM
  • 55,688 POSTS
just the handle, and yes you must remove the headliner to service the moon roof
Sep 20, 2007 at 3:31 AM
TREKINOUS
  • 28 POSTS
thanks for the help! turned out it was stripped. thanks a million.
Sep 21, 2007 at 2:41 PM
  • 55,688 POSTS
no problem, that what we are here for.
Sep 24, 2007 at 10:23 AM
