1992 Jetta Alarm problem
1992 VOLKSWAGEN
PHEIM
The car will not start - alarm light (drivers side door lock) blinks constantly. Unlock door with key and open - Alarm sounds (horn blows) - put key in ignition alarm silences but car will not start.
Can the alarm be disabled? Is there a chip in the key - that has failed? Just not sure what is wrong - Can anyone help - other than towing it to the dealer??
Nov 4, 2007 at 9:34 AM
BMRFIXIT
  • 19,053 POSTS
[quote:377e0aa5d2="PHeim"]The car will not start - alarm light (drivers side door lock) blinks constantly. Unlock door with key and open - Alarm sounds (horn blows) - put key in ignition alarm silences but car will not start.
Can the alarm be disabled? Is there a chip in the key - that has failed? Just not sure what is wrong - Can anyone help - other than towing it to the dealer??[/quote:377e0aa5d2]
try to use other door lock and or trunk
and if work you have a problem in that door and not the alarm
good luck
Nov 4, 2007 at 11:36 AM
PHEIM
Alarm is going off - even when we unlock passenger door. Car still will not start. Is there a way to disable alarm?
Nov 17, 2007 at 6:34 AM
BMRFIXIT
  • 19,053 POSTS
[quote:0b06e9f62c="PHeim"]Alarm is going off - even when we unlock passenger door. Car still will not start. Is there a way to disable alarm?[/quote:0b06e9f62c]
DID U TRY THE TRUNK
AND IS IT AFTERMARKET ALARm if yes look for a switch under steering column area
and if factory and none of the locks working u have to take one of the panel off to check the switch in the door
good luck
Nov 17, 2007 at 8:10 AM
PHEIM
[quote:98da053b18="BMRFIXIT"][quote:98da053b18="PHeim"]Alarm is going off - even when we unlock passenger door. Car still will not start. Is there a way to disable alarm?[/quote:98da053b18]
DID U TRY THE TRUNK
good luck[/quote:98da053b18]
No did not try trunk, did read how to disable alarm under the dash - take out knee plate. Alarm has 10 pin connector and 6 pin connector - disconnect both and short pins 5 and 6 on the 6 pin connector (red and red/black wires). Car starts and runs fine - no alarm - no big deal. Thanks for all your suggestions and assistance. Thought the information may help someone else in my predicament - dealership told me it was probably the lock assembly on the driver door - stuck in locked and armed position.
PH
Nov 29, 2007 at 1:47 PM
