1998 Volkswagen Jetta clutch
1998 VOLKSWAGEN JETTA
160,000 MILES • 4 CYL • FWD • MANUAL
NITA.NILSON
after replacing the release bearing the clutch release rod is not returning to original position. The clutch doesnt seem to slip, but we have to start car in gear in order to drive. The clutch pedal is sitting next to the floor.
Do we need to replace the whole clutch?
Aug 18, 2009 at 3:49 PM
STEVEW84
  • CERTIFIED EXPERT
  • 673 POSTS
Can you see the slave cylinder push the release lever?
Aug 18, 2009 at 8:33 PM
NITA.NILSON
No, and we only have a bad diagram. doesnt show where the slave cylinder is. Do you have access to a better diagram?
Aug 20, 2009 at 3:01 PM
STEVEW84
  • CERTIFIED EXPERT
  • 673 POSTS
Just follow the clutch cable and you will find the other end. The end is where the release lever should be. If you need a diagram send me an e-mail at underthecarguy@aol.com with the size 4 cyl you have.
Aug 20, 2009 at 3:28 PM
NITA.NILSON
Hi Steve, I've sent an email to you. Thank you for your help!!
Nita - yahoo email
Aug 20, 2009 at 6:04 PM
