1989 Volkswagen Jetta Clutch/transmission.
HEARTSIC6SIX
Transmission problem
1989 Volkswagen Jetta 4 cyl Front Wheel Drive Manual
The car will go into gear but transmission will not engage. Even in first or fifth gear, if you let off the clutch...nothing happens- it keeps idleing. We had replaced the clutch a week ago. Do you know what is causing this to happen? and how can we fix it?
Thank you!
Dec 21, 2008 at 4:32 PM
  • 31,937 POSTS
Hi there,
if you can select gears with no motion happening either the clutch hub has failed or you have a broken input shaft in the transmission, either way the transmission will have to be removed to inspect for this fault.
mark (mhpautos)
Dec 21, 2008 at 7:10 PM
