1998 Volkswagen Jetta clutch or ? big repair bill?
291,000 MILES • 4 CYL • FWD • MANUAL
WESTCOAST_DAVE
Driving to work today and without warning it becomes difficult to shift gears, as though the paths in between gears are much less defined and it's more difficult to get car into gear (especially low gears).
At a stoplight it won't even shift into any gear after moving it into neutral while trying to downshift. Finally am able to get it into first and continue by turning off ignition, putting it into 1st, and restarting car.
Even while moving shifting is 'difficult'.
Is my clutch gone? Clutch cable? Or..?
Any insight appreciated.
Sep 21, 2010 at 5:26 AM
YOUNGIN-ON-HIS-GRIND
hey i would check your shifter cable
Nov 8, 2010 at 7:15 AM
DOCFIXIT
  • 18,828 POSTS
Clucth system is hydraulic activated check fluid level of clutch master cylinder. And look for leaks at master ans slave on transaxle.
Nov 8, 2010 at 7:24 AM
WESTCOAST_DAVE
thanks Doc & youngin
Will see what we can come up with.
Much appreciated!
Nov 8, 2010 at 8:10 AM
