1986 Volkswagen Jetta starting problem
FIONPALM
  • 1986 VOLKSWAGEN JETTA
Electrical problem
1986 Volkswagen Jetta Two Wheel Drive Automatic
I had an ignition problem on my 86 jetta(I had to hold my key in a certain spot so it would run. I cut the two black ignition wires from the ignition and ran a hot wire to them and it worked for one day. Now it just turns over but will not start. I have spark and fuel
Tuesday, September 28th, 2010 AT 2:27 PM
  • 109,758 POSTS
Is the spark a hot blue snapping spark? Have you actually checked fuel pump pressure?
Tuesday, December 20th, 2016 AT 11:55 AM
FIONPALM
Gave it a tune up and fired right up guess spark must have been a bit weak
  • 109,758 POSTS
That's good news. Glad you got it going.
Take care and let us know if you have questions in the future.
