1986 Volkswagen Jetta 4 cyl Two Wheel Drive Manual Jetta miles
I have an 86, 8 valve jetta that wont start. It would crank over but had no spark. I tested the coil, battery, ignition control module, hall effect connector and the igniotion switch for the right voltage and all seem to be fine. I let it set over night and now I can't get it to even crank over or even get a click out of it. I replaced the control module and re tested everything for the proper power and it still does not crank over. Could it be the coil? Or what else can I try to test. There is power to everything. I just don't understand how it would crank over and not start and than not crank over at all when there is still good power to the components I tested.
SPONSORED LINKS
Friday, April 18th, 2008 AT 7:20 PM
