Valve cover torque specs
148,000 MILES • 1.4L • 4 CYL • TURBO • 2WD • AUTOMATIC
GERALD NICHOLS
What are the torque specs for the car listed above's valve cover?
Aug 6, 2020 at 2:47 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Here is the information you requested.The torque specification is 8 Newton Meters or 71 Inch Pounds. I've attached a picture below showing the proper torque sequence of the bolts. Here is a valve cover replacement tutorial:
https://www.2carpros.com/articles/replace-valve-cover-gasket
Hope this helps and thanks for using 2CarPros.
Aug 6, 2020 at 3:03 PM
