Check engine light came on I had a diagnostic ran on it and came back with the code P0171. they told me i need a vacuum control assembly valve, $217.00, but also says a broken hose on vacuum runner valve? is this the same part? and upon further inspection we found that there is a large crack in the air breather housing which had been duct taped, the tape has come loose and I am wondering if this could have been the problem the whole time? can you help me, as I am not able to keep pouring money into this with hit and miss sensors and such? I am unemployed at the moment and just cannot afford to. any advice would be appreciated. thank you.
Jul 27, 2016 at 7:46 AM
